Well I have left the Audi side of VAG with dreams of good MPG and smog exempt goodness, and heres what I brought home. vduber_g60's old 1981 VW Rabbit Diesel 1.6 N/A. 248k on the clock but running strong (well... now...). AVO GTX coilovers, 13" mags, a "ram" air tube (kind of.. to be replaced) and an idle cackle only a mother could love.
The first day driving her home on the highway the car -would not- reach 65mph unless it was downhill (and the wind was right). After the highway it almost didnt make it up my driveway to my house (up a kind of steep hill). I of course figured the diesels are slow... but nothings that slow / gutless. I hit the Hayes manual and did some tinkering, found the injection pump wasn't tuned properly (fuel was set too lean, and the WOT/rpm stop adjustment was set at a point so you couldn't actually ever go full throttle
). 20 mins later I was giddy as a school girl. Bombed back down the hill, the car was a new beast. Hit 60 in third gear getting on the highway when it couldnt hit 65 in 3 miles before. Climbed back up my driveway in 2nd gear without touching the throttle pedal
.. I figure I have the tuning set pretty much good for now. I want to wait to replace the high mile injectors before continuing messing with anything.
Car has the bumpers pulled (came with em), also came with the stock wheels, caps & trim rings. With 247k (now 248k) on the clock I am glad she's running strong but I will be bench building a 1.9T AAZ & a 5 speed for swapping in sometime this coming winter (hopefully). I ordered an EGT kit and will be mounting that up whenever it arrives, try to keep this old 1.6 going as long as I can.
About 2 days later I realized I had no running lights. Brake lights worked, turn signals, headlights, but no rear running lights. I traced the wiring loom searching for shorts but nothing, turns out the headlight switch (very common to fail) burned out & melted the pot where the running lights connect to. When replacing the switch I will be relaying the front headlights, using LED bulbs in the rear & putting an inline fuse on the wire that shorted with a 5a fuse in just in case I missed something along the line. Got some shopping done over the weekend, now waiting for the mail man...
Parts on order:injectors x4
heat shields x4
new tail lights
new headlight switch
new front turn signals (clear)
mercury bulbs for front signals
new e-brake cables x2
timing belt service items (belt, tensioner, waterpump)
air filter
fuel filters
oil filters
low temp thermostat
low temp fan switch
LED rear running / brake lights (to reduce draw on headlight switch)
2x 30a relays (to relay the headlights, further reducing draw on the switch)
new rear hatch struts x2
3" silicone connecting tubes (for my CAI build)
valve cover gasket
Anyways, enough blabbin, time for pics..
(TD badge to be removed..)
I am going away from the 13's and will be mounting up some 195 45 15's in the near future so i can utilize the coils and bring her down low. Right now with the 205 60's there's no way i can go much lower without larger flares and some sawzall work. I also need to adjust the coilovers as the car doesn't currently sit completely flat (in the rear, driver side has a 1 finger gap, passenger side has 2.5, in the front the driver side has 1.5 gap, passenger side has .5).
Looking for a few parts as well, if anyone knows where to find em it'd be greatly appreciated:
New headliner
black side trim
More to come....
