So I want to change my belt soon, just to be safe.Heres the thing...if I mark all of the pulleys and the old belt, then transfer the marks to the new belt, and make sure none of the pulleys move(timing, crank, cam)...is it safe to put the belt on and drive it, or will it still be out of timing range??This is a temporary thing until later this month when I will actually have time to do the headgasket!!!
I have always had a issue with changing the belt/timing the pump... When changing/adjusting the belt do i leave the pump pin in place when applying tension?Do i leave the camshaft lock plate in when i apply tension or do i need to remove it when applying the tension?Once the marks are lined up how many rotations do i do? 1 full rotation or 2? i heard 2 but want to double check(I always seem to be exact on timing marks but the flywheel is always off once i apply tension and spin it a full rotation)
