That is a rather unique combination - did VW put that on any of it's motors or were all the GTD nozzles originally put into 1-spring bodies? Did the GTD nozzles just drop right into the 2-spring bodies? Thanks for the info... very interested in your test results.
Did you look at the nozzles hole? Do the GTD nozzles have significantly bigger hole? :arrow: :?: Smog, what size hole the GTD nozzle do have, you know? :?: :?:
Overall I would recommend these nozzles. I would expect that those those running 1.6TD's will get even better results. G-tech results will have to wait until the next GTG that Giles attends...
any news about the injectors since the first drive ?
There is really nothing in the pump that is unique to one cylinder so I don't think it could be the problem
The pump has seperate delivery valves for each cylinder. I have swapped them out and gotten rid of a miss in one cylinder. They are on the end of the pump. The injector lines screw onto them
