Can you explain the vise grip trick?
Awesome. So do you have a TD pump? Stock turbo?
Very nice Can you explain the vise grip trick?
r with thermostatically controlled fan
rainbow electronics sells a thermostat that opens at 0C - 120C pretty cheap too... I have one
Nice ride!Quote from: larry104r with thermostatically controlled fan Where did you get the thermal switch? At what temps does it turn/turn off?
Quote from: "jackbombay" Where did you get the thermal switch? At what temps does it turn/turn off?Electronic Surplus. Normally open and closes at 120 deg F. It's attached to the surface of the intercooler at the inlet side.
Quote from: larry104Quote from: jackbombay Where did you get the thermal switch? At what temps does it turn/turn off?Electronic Surplus. Normally open and closes at 120 deg F. It's attached to the surface of the intercooler at the inlet side. I couldn't find such an item on their website, was it listed under "thermostat" or "thermistor"?EDIT- Is this the one you used?
