Author Topic: mTDI / TDI-M Injection Pump FAQ  (Read 326128 times)
Reply #105September 01, 2010, 04:34:50 am
  • 5318
Re: mTDI / TDI-M Injection Pump FAQ
« Reply #105 on: September 01, 2010, 04:34:50 am »
if you want a m-tdi pump contact hey or namedtintin in vwquébec or me in france
Reply #106September 05, 2010, 10:31:27 am
UAofE
  • 13
« Reply #106 on: September 05, 2010, 10:31:27 am »
Can anyone point me to information on a 5-cylinder Audi distributor pump (mIDI)?
Reply #107September 06, 2010, 07:32:02 am
ChopSauce
  • 515
« Reply #107 on: September 06, 2010, 07:32:02 am »
Out of curiosity : can't one just fit the complete head with springs and camplate into any mTDI pump ?
Reply #108October 31, 2010, 08:17:10 pm
jabcok20
  • 15
    1.7 m-tdi vnt20 electronic map sensor
« Reply #108 on: October 31, 2010, 08:17:10 pm »
hey and 410
i have timing spring from 1.9td and i give there someting about 1,0 mm more washer.
the engine is going 120km/h on 3 gear so this is something about 5500 rpm ( CHD gearbox).
i have lda , pin is much more agressive. and i ave a little bit of too early injection on low rpm.
regulation valve ( that thing wchich we use to set pressure in the pump)   have big mouth and soft spring.
« Last Edit: October 31, 2010, 08:21:08 pm by jabcok20 »
Reply #109October 31, 2010, 10:11:22 pm
410
  • 581
« Reply #109 on: October 31, 2010, 10:11:22 pm »
Jabcok20, pm sent.
Toyota truck 4x4 with Mtdi, M-vnt gt1749va, 11mm pump, fmic, smog .216 nozzles.  Sold!
Reply #110December 20, 2010, 10:36:56 am
jabcok20
  • 15
« Reply #110 on: December 20, 2010, 10:36:56 am »
Also, 1.9td regulator wont work with 11mm pump!!
Tell me why?
Did the pressure in the pump is too low in low rpms?
I have 1.9td regulator and at cold engine i have wite smoke and i looks like pressure was to low. when engine was warm the smoke disappear.
Reply #111December 20, 2010, 12:26:46 pm
« Reply #111 on: December 20, 2010, 12:26:46 pm »
That's what I'd do for a 5-cyl mTDI.  I've never taken apart a 5 cyl pump, but I imagine that you'd also need to use the roller cage and rollers (are there 5 rollers?).  That might cause some added complication as the electronic pumps don't have the cutout in the roller cage to accommodate the governor.  Some machine work there would likely be in order.
only 3 rollers in a 5 cyl Audi pump..
Reply #112December 20, 2010, 12:27:14 pm
« Reply #112 on: December 20, 2010, 12:27:14 pm »
Tell me why?
where do 1.7 tdi engines come from?
Reply #113December 20, 2010, 12:30:51 pm
410
  • 581
« Reply #113 on: December 20, 2010, 12:30:51 pm »
Tell me why?
I am using 1.9td regulator and advance pistons with stock shims with 11mm pump and am quite happy with it.  I wish I hadn't deleted the cold start lever though.
Reply #114December 27, 2010, 07:11:46 pm
snakemaster
  • 405
« Reply #114 on: December 27, 2010, 07:11:46 pm »
some pics of pump stuff  top 5 cyl 2.4 idi  , middle 4 cyl 1.9 , and bottom 5 cyl 2.5 tdi  , due to the gov the 5 cyl idi only has 3 rollers you can see where thay sit with the rust ,this pump had bio diesel in it and was rusty and gumed up with waxy crap ,and so was the 4 cyl 1.9 to
Reply #115January 08, 2011, 07:37:01 pm
jabcok20
  • 15
« Reply #115 on: January 08, 2011, 07:37:01 pm »
by this day i think 1.9td regultor won;t work with 11mm. I must say that i think pressure in the pump is to low and car have white smoke on cold engine.
410 have that regulator and he is happy, but i try everything and white smoke don;t dissapear( this is a lot of smoke). But something about 3,5 bar white smoke is weakness and i put one pad into regulator, there is ok but timing don;t go to the end of regulator. rpm' goes something about 500 lower than before but engine works queitly.
Reply #116May 04, 2012, 06:50:57 pm
Hey
  • 339
« Reply #116 on: May 04, 2012, 06:50:57 pm »
Just an update. I am still running the same car with the same pump.
Jetta 96, VG-mTDi/hybride td, 20psi, IC, 10mm camplate de tdi, .205 et CTN
Reply #117May 04, 2012, 07:28:54 pm
410
  • 581
« Reply #117 on: May 04, 2012, 07:28:54 pm »
Nice to see you still check the site Hey.  My pump is still going strong too with over 40,000km on it.
Reply #118May 05, 2012, 04:16:03 am
DA-BRT
  • 140
    • http://Zwalve.eu/
« Reply #118 on: May 05, 2012, 04:16:03 am »
I build a 2.5 TDI in my Audi 100 from 1977 and I also had the issue with the rollers and I solved it like this:
Original 2.5TDI pump
Comparison between the roller houses
New one with 4 rollers instead of 3.
New pumphouse.
I've been driving for a good 10.000km with this pump and a friend of mine is driving a NK offroad car (paris dakar type of vehicle) and we also build in a 2.5 R5 TDI engine with the same pump. With DSS ultime nozzles a VNT22 he has got more than 300HP and almost 650Nm on all 4 the wheels. When I get the dyno sheet I will post it.
Reply #119October 31, 2012, 09:38:06 pm
410
  • 581
« Reply #119 on: October 31, 2012, 09:38:06 pm »
I just picked up an aaz pump with an adjustable pulley thinking that it might have a 20mm shaft.  Sadly it is only a 17mm shaft.
S-PAutomotive.com
