Hey guys,
Well I checked my IP pressure @ 1000 RPM which was at 28PSI
Before adjusting, I checked at 2000RPM as well (also very low)
While holding RPM @ 2000 for over 30 seconds- I think my true problem showed
Air Bubbles in the clear line to IP !
No bubbles at idle,but after 30 seconds at 2K, the bubbles started flowing-and got worse the longer I held the RPM
This really pisses me off !
A year ago, I installed a NEW fuel tank,new one piece steel feed line and new one piece return line-
From tank to firewall- no fittings or splices-all one piece- to avoid this from happening.
I had also installed a new OEM lift pump,in the tank.
It is a free flowing pump (meaning- with pump OFF- fuel flows freely thru it)
At the time,I had read many posts about using a lift pump
Some people swore it was a good idea,some people swore it was a bad idea
I figured-sence it was a free flowing pump, I could easily disable it by removing the pump relay (this is in a Fox 1.6TD conversion)
So- I have been running with pump off
Guess what- I put the pump relay back in
with pump ON,no more air bubble at all (and no leaks) and IP pressure increased to 35PSI
So I adjusted pump pressure to 43 PSI @ 1000RPM with pump ON
Now have very little fuel smoke at idle,don't see any smoke behind me while driving,turbo seems to spool a little sooner,engine sounds better-power is still about the same though (may be partly due to gearing (2500RPM @ 65MPH)
I will run it this way for a while,to make sure smoke is gone,than maybe I can turn fuel up a bit,to help power
