Most of the things I seem to relay are in the engine bay. Keeping wires from going through the firewall if they don't have to. But this wires goes through the cab on it's way to the back so when I finally did relay the reverse lights I used the spot for the fuel pump relay, on the fusebox. This was with a Rabbit but it had the same wimpy switch. The fuel pump relay spot still had all the wires hooked up, one fat wire heading toward the back Green/BLack?, even though the diesel doesn't use it. I moved it's place in the rear harness 10gray plug, the wire that used to go back to the lights now triggers the relay.
