What bolts/studs are you using.Use the procedure they call for, in the order they call for.
I don't have an aaz bentley but if you know whatever the aaz engine HG sequence is that is what I would use.
Things that would be helpful:1) whether or not the AAZ procedure shares the extra torquing procedure2) whether or not the stock AAZ head bolts stretch
I had a metal head gasket from aaz installed on my 1V engine1.6td hydraulic headOem stretch boltsThe torque procedure is the same as the fibre gasketSame torqueThe only difference is you don't re torque afterjon
My Bently has different procedures for fiber versus metal HGs on AAZ's... I don't have it handy at the moment though. I'll try and find and post the specifics later!
