Fixmyvw.com
Author Topic: vented disk upgrade.  (Read 4788 times)
August 02, 2011, 09:58:24 pm
  • 2787
« on: August 02, 2011, 09:58:24 pm »
The '92 golf needed brakes very badly so I bought vented GTI disk and pads to fit. GTI pads are thinner to compensate for the thicker disk but appearantly I have the wrong calipers because even though I compressed the piston completely I can't get it to fit over the disk/pad assembly.
Anyone know if that's what's going on here?
« Last Edit: September 02, 2011, 06:01:55 pm by rabbitman »
Reply #1August 02, 2011, 10:21:46 pm
  • 7837
Re: Attempting to upgrade to vented disks.
« Reply #1 on: August 02, 2011, 10:21:46 pm »
I did the swap on my jetta and I thought all the calipers were the same on the solid rotor cars. Mine were a bit tight, but they went on. Maybe try a bigger hammer and let the extra burn off slowly while driving???
Reply #2August 02, 2011, 11:53:00 pm
wdkingery
  • 494
« Reply #2 on: August 02, 2011, 11:53:00 pm »
hahahaha durty!!
Reply #3August 03, 2011, 01:20:03 pm
  • 2787
« Reply #3 on: August 03, 2011, 01:20:03 pm »
So I looked into it more and I've got PBR D539D pads which are for vented rotors and 25243 vented brembo rotors.
The pads fit in the carrier perfectly with the rotor in place but when I try to put the caliper on there's at least an 1/8th inch of interferance and I'm sure the piston is compressed all the way..........
Anyone know if euro golfs have a slightly different caliper than USA models?
« Last Edit: August 03, 2011, 02:15:41 pm by rabbitman »
Reply #4August 03, 2011, 02:32:12 pm
  • 2787
« Reply #4 on: August 03, 2011, 02:32:12 pm »
Ok I found some calipers off a solid rotor jetta to compare.
The jetta ones are wider and fit over my rotor/pad setup >:(. So vw did a weird thing and put solid rotor only calipers on my golf. I could use the jetta ones I found but they're well used already so I'm gonna price new ones.
Reply #5August 03, 2011, 03:22:37 pm
  • 7837
« Reply #5 on: August 03, 2011, 03:22:37 pm »
Rockauto has some loaded calipers for around 40 dollars. That is what is on my car. I have a Rockauto code as well for a little off the total too.
Reply #6August 03, 2011, 05:21:22 pm
« Reply #6 on: August 03, 2011, 05:21:22 pm »
my 92 jetta, i went from solid disks to vented ones, didnt have to change the pads (mine were worn just right) but it all fit together just fine..
the calipers liked the new hardware just fine..
Reply #7August 04, 2011, 12:49:22 am
  • 2787
« Reply #7 on: August 04, 2011, 12:49:22 am »
Yeah I'll have to look into some wide calipers, the brakes that are on it are way junk and I'm not gonna buy new solid rotors.
Reply #8August 05, 2011, 08:56:09 pm
  • 1739
« Reply #8 on: August 05, 2011, 08:56:09 pm »
we used to retro fit all the mk2 taxis that we were servicing so they would brakes that lasted more than a couple of weeks. discs and pads fit right in.
the worse one we saw was 1 week, 11,000 kms, worn to the metal.
Reply #9August 05, 2011, 11:07:52 pm
  • 2787
« Reply #9 on: August 05, 2011, 11:07:52 pm »
That's crazy!!!! Seems like you'd have to way over brake to wear 'em that fast. :o
Reply #10August 06, 2011, 03:45:43 pm
  • 1739
« Reply #10 on: August 06, 2011, 03:45:43 pm »
they were running 24/7 with 2 or 3 driver shifts. plus we are talking about Montreal traffic
Reply #11August 08, 2011, 02:20:22 pm
  • 2787
« Reply #11 on: August 08, 2011, 02:20:22 pm »
Waiting for rebuilt calipers from amazon. $35 each.
Reply #12August 09, 2011, 04:39:32 pm
carrizog60
  • 978
« Reply #12 on: August 09, 2011, 04:39:32 pm »
easy way:
if they(the calipers) say vwII they will fit,if not,well,buy ones that say lol
Portugal
Reply #13August 09, 2011, 04:47:18 pm
« Reply #13 on: August 09, 2011, 04:47:18 pm »
easy way:
genius!
cause all my calipers say that..
except my girling 54's off the GLI..
Reply #14August 11, 2011, 03:47:17 am
Pat Dolan
  • 163
« Reply #14 on: August 11, 2011, 03:47:17 am »
I have ridden in Montreal taxis...believe me, crazy is the word, allright.
lifetime VW enthusiast, racer, fixer, addict, etc.
'03 TDI Variant, MkII Golf Country, Mk1 and II Scirocco (gassers), a Vanagon aircooled, an Audi 2.0 TD waiting to become a Porsche TD (in my M471 924), FLD120/DDEC IV, Ford 7.3/450, Iveco D220 and some 6D14T Mitsus and a few more.
S-PAutomotive.com
