So, did you remember to swap out the gear on the end of the speedometer to the correct color one after you swapped the transmissions?
^Torque, or Inertia?so...how much weight did you save?
Quote from: 745 turbogreasel on May 28, 2011, 02:57:37 am^Torque, or Inertia?so...how much weight did you save?I dont know how much the stock diesel FW weighs, but if you do than math can be our friend. The new FW weighs 8.75 lbs.I am curious as to how it well effect torque? Is it just a gasser way of thinking that by freeing up any mass the engine doesnt have to spin, push, pull, its a help? I was also wondering about lightweight pulleys? Does anyone even make em?
whats an aaz 210mm??
