You could still have the woodruff slot cut anywhere on the crank, tho. I should have said, you're SOL WRT using the TDI sprocket.You could upgrade the crank and then use the TDI sprocket.
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..
