VWDiesel Blog
Facebook Group
VWD on Twitter
foxracer1's Race only Daily Driver build and KILL thread
4
Topic: foxracer1's Race only Daily Driver build and KILL thread (Read 11088 times)
January 19, 2010, 02:58:25 pm
foxracer1
Authorized Vendor
January 19, 2010, 02:58:25 pm »
Ok this is gonna be long. Mostly pics cause i don't like to type. But at the same time as i'm building the car i didn't take as many pics as i wished i would have. And when i did it was with a camera phone so quality is marginal.
Bought the car in Jan 2008 like this:
Last Edit: February 03, 2010, 09:32:50 am by foxracer1
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
January 19, 2010, 02:59:07 pm
foxracer1
Authorized Vendor
Re: foxracer1's Race only Daily Driver build thread
January 19, 2010, 02:59:07 pm »
More pics of the way the car was when we arrive in kansas.
Most of the wires were chewed up by animals. there was a large nest right on the valve cover and bite and scratch marks on the outside from dogs trying to get the rodents.
Last Edit: January 19, 2010, 03:13:27 pm by foxracer1
91 S10 305 TPI T56
January 19, 2010, 03:04:43 pm
foxracer1
Authorized Vendor
January 19, 2010, 03:04:43 pm »
On the way home got 2 cars 85 and my 86 both TD cars
Waiting for me to fix her up!
Turbo was off mine. I started with a turbo in pieces that i didn't take apart. Got a g-pop kit with the car.
Put it together...But not with out modifying it!
91 S10 305 TPI T56
January 19, 2010, 03:11:56 pm
foxracer1
Authorized Vendor
January 19, 2010, 03:11:56 pm »
More turbo mods. Welded the port between the turbine exducer and wastegate, to eliminate turbulance in the exducer. Now i must use a seperate wastegate dump pipe.
Got it running after re shiming the valves installing a new headgasket and pull starting it cause she wouldn't light with just the starter
Last Edit: January 19, 2010, 05:55:53 pm by foxracer1
91 S10 305 TPI T56
January 19, 2010, 03:21:37 pm
foxracer1
Authorized Vendor
January 19, 2010, 03:21:37 pm »
Got a full jetta III suspension with rear disc and beam. The front control arms are out of a passat and are 1 inch longer.
Sittin sky high!
Found some lowering springs put them on new struts for the front the rear got new HD struts. Tried various rims to see what i liked.
On my way to detroit to pick up a friend to drive to Waterfest 14 she tried to run away on her blow by(i was hauling a trailer with a washer dryer and other random crap). So he came and got me in his 81 280k mi rabbit truck and we made the trip.
91 S10 305 TPI T56
January 19, 2010, 03:44:19 pm
foxracer1
Authorized Vendor
January 19, 2010, 03:44:19 pm »
Decided it was time to rebuild the engine. Funds were low as usual so thought i would just rering it. Well engine needed to be bored... .040 or 1mm over! The head was an AMC mechanical. The block is HYD! So the head had been off before we got to it.
Premium CAT YELLER engine enamel
Fresh 77.5mm bore and pistons
ARP head studs
New no name 1.9 head!(from 91redjetta)
G60 valve cover with AN fitting welded in for breather
1.9 1 notch MLS HG
Windage oil pan gasket
91 S10 305 TPI T56
January 19, 2010, 03:47:52 pm
foxracer1
Authorized Vendor
January 19, 2010, 03:47:52 pm »
10mm highly modded pump
All painted up
custom painted "BIG HAWZ HIGH RAM" knock off intake elbow! thanks to my buddy Jase for that one
Powered by RED BULL wouldn't have gotten what i have done with out long nights at Sams(91 redjetta) place fueled by lots of red bull
9Atrans with .75 5th (has since gotten stuck in 3rd and swapped for an AUG w/ same .75 5th
Last Edit: January 19, 2010, 03:52:56 pm by foxracer1
91 S10 305 TPI T56
January 19, 2010, 04:03:30 pm
foxracer1
Authorized Vendor
January 19, 2010, 04:03:30 pm »
Goin back in
Didn't take many pictures for awhile for some reason. Must have been enjoying the new engine so much.
3 days before Waterfest 15 decided to paint the roof and hood! Roof got checkers very time consuming to tape off. Didn't think it out that much before and realized after i was in to far to stop. Had a moth land in the final coat of clear and flail around releasing his moth dust and messing up a white sqaure. But other than that turned out good. Thanks go to my buddies dad joe for running the gun and use of the shop. Hood got painted black in the middle. Need to wet sand both and it'll be good enough. Wanna paint the rest of the car stock color. Some day.
91 S10 305 TPI T56
January 19, 2010, 04:07:28 pm
foxracer1
Authorized Vendor
January 19, 2010, 04:07:28 pm »
Need to get up to date pics.
Got a quad round grille
pics of the full 3" turbo back exhaust somewhere
late MKII big bumpers painted black
Sirroco front seats
Things coming this month
VR6 brakes and 5 lug swap
ASA 17" wheels
Intercooler
Dyno time
More fuel
water meth
LP even though everyone says its not worth it
Gotta thank My friends Jase and Sam(91redjetta) for all the help. There were others i'm sure but thoses 2 mostly. Gotta thank sam for all the race only parts wouldn't have happened with out him and his dads collection of VWs and parts.
Last Edit: January 19, 2010, 04:21:54 pm by foxracer1
91 S10 305 TPI T56
January 19, 2010, 04:09:07 pm
January 19, 2010, 04:09:07 pm »
That yellow is like sunshine in your engine bay
January 19, 2010, 04:14:00 pm
foxracer1
Authorized Vendor
January 19, 2010, 04:14:00 pm »
Got the car with 124,xxx in march of 2008 started driving it. Drove it a few thousand with a broken odometer fixed that. Car sat 4 months while getting rebuilt. It now has 149,xxx. I love driving it.
Its been to NJ, CT, Al, all over ohio, IN, and the surounding areas!
Posted by: 745 turbogreasel
"That yellow is like sunshine in your engine bay"
Last Edit: January 19, 2010, 04:19:51 pm by foxracer1
91 S10 305 TPI T56
Reply #11
January 19, 2010, 05:02:30 pm
91redjetta
Reply #11 on:
January 19, 2010, 05:02:30 pm »
ya its pretty much the fastest thing i know! ha
Reply #12
January 19, 2010, 07:58:25 pm
NintendoKD
dnahtasinoivilboeraweb
Reply #12 on:
January 19, 2010, 07:58:25 pm »
WOW! looks nice guys, where did you get that oil baffle? Also, you sent your IP to giles or no? I'm building a frankenengine or also known as a frankenmotor. Inspiration is a wonderful thing, so thanks.
Kevin
Reply #13
January 19, 2010, 08:16:55 pm
foxracer1
Authorized Vendor
Reply #13 on:
January 19, 2010, 08:16:55 pm »
I believe i ordered the headgasket and pan gasket from myke_w on here. I believe the gasket came on late MKIII2.0l and most engines after that.
I did all the pump work myself. 91redjetta had a 10mm TDI pump that i used parts from.
91 S10 305 TPI T56
Reply #14
January 19, 2010, 11:43:23 pm
Powered by Spearco
Reply #14 on:
January 19, 2010, 11:43:23 pm »
Thats bad a$$
. Got any video of it, hows it sound?
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
4
