Author Topic: Identify IDI pumps by part number?  (Read 10020 times)
December 26, 2009, 02:42:04 pm
trev
  • 67
« on: December 26, 2009, 02:42:04 pm »
Been digging around the net looking for this info. Maybe my Google-fu is weak these days.
Is there a reference page out there that can tell me how to translate a Bosch pump's stamped numbers into relevant info I can use?
For that matter, what differences are there amongst the 4 cylinder VE pumps. Off the top of my head, things I can think of would be the vane pump size (Yes? No?), the plunger pump bore size (pretty certain on that one) and the cam profiles/heights ( or are they all pretty much the same?).
Or are the part numbers even translatable like that?
Not looking to get into the hop-up biz, really looking to see if there is a reference I can use to check if a pump I might pick off a bench might be useful to me, without knowing what it came off of.
Cheers
 Trev
Reply #1December 26, 2009, 06:14:31 pm
Re: Identify IDI pumps by part number?
« Reply #1 on: December 26, 2009, 06:14:31 pm »
You can decipher that by locating the Bosch p/n on your pump.
Bosch VE P/N Example: 0 460 494 001
Key to Bosch Part Number:
0= Denotes complete product
460= Product class, Distributor pump
4= Identifier for VE Injection pump
9= Plunger Diameter: 8=8mm,9=9mm,0=10mm,1=11mm,2=12mm,3=13mm & 4=14mm
4= Number of Cylinders
001= Application
Reply #2December 26, 2009, 11:52:59 pm
« Reply #2 on: December 26, 2009, 11:52:59 pm »
Isn't one of the digits the direction of rotation?
by this its in the other number...
It turns out the last three digits of the VP37 marry up to another bosch part number that gives more information. The new code breaks down as follows:
VE = VE type pump (VP is still a VE pump)
4 = number of cylinders
/10 = 10mm plunger
E = electronic governor (F=mechanical)
xxxx number = governor controlled RPM (I assume this is pump rpm not engine rpm)
R = clockwise rotation (L = counter clockwise)
xxx-x number = production number
Reply #3December 28, 2009, 12:26:04 pm
trev
  • 67
« Reply #3 on: December 28, 2009, 12:26:04 pm »
Handy info! Thanks!
Cut from another site, or from a manual somewhere?
 Cheers
  Trev
Reply #4December 28, 2009, 01:32:10 pm
peacedub
  • 49
« Reply #4 on: December 28, 2009, 01:32:10 pm »
this is interesting information, is there a decoder available?
mine is NR 0 460 494 185, that part i under stand, but i would like to know my rpm limit...
THIS IS THE FULL THING:
NR 0 460 494 185
VE R 134-2
VW AUDI 068130109Q
011 351 27560
PEACE
Reply #5December 28, 2009, 06:32:27 pm
« Reply #5 on: December 28, 2009, 06:32:27 pm »
I think the first might be quoted from this site ;D
not quoted form a manual by me.
Reply #6December 28, 2009, 11:42:06 pm
subsonic
  • 1836
« Reply #6 on: December 28, 2009, 11:42:06 pm »
« Last Edit: December 28, 2009, 11:49:08 pm by subsonic »
