Is yours a GT1749VA? Do you have calipers? Can you measure your housings and fans and I'll tell you if it's the housing or the fan. Probably most cost effective would be to get a replacement turbo or center section.Andrew
Looks fishy...
thats a shame about the turbo... the noise you're hearing is the pressure leaking past the blades the turbo is probably doing more harm than good the way it is. i'd definitely hit prothe up for a center cartridge if you can confirm it will work. people can talk trash about those turbo's all they want, but they do have quality control. just make sure you don't go too crazy with boost and it should be fine. even the expensive 'oem' turbo's can fail and destroy an engine, so i personally think its a toss up.i wouldn't pay more than $400 to get your turbo up and running. for that price you could get a real nice vnt20 off of a diesel jeep, and never worry about destroying the turbo (you'll destroy your engine first )
Quote from: jtanguay on June 26, 2009, 11:27:11 pmthats a shame about the turbo... the noise you're hearing is the pressure leaking past the blades the turbo is probably doing more harm than good the way it is. i'd definitely hit prothe up for a center cartridge if you can confirm it will work. people can talk trash about those turbo's all they want, but they do have quality control. just make sure you don't go too crazy with boost and it should be fine. even the expensive 'oem' turbo's can fail and destroy an engine, so i personally think its a toss up.i wouldn't pay more than $400 to get your turbo up and running. for that price you could get a real nice vnt20 off of a diesel jeep, and never worry about destroying the turbo (you'll destroy your engine first )I can't imagine where you all find these turbos all the time for those prices. Around here the junkyards wouldn't consider selling a turbo off a good engine.
... the noise you're hearing is the pressure leaking past the blades the turbo is probably doing more harm than good the way it is. i wouldn't pay more than $400 to get your turbo up and running. for that price you could get a real nice vnt20 off of a diesel jeep, and never worry about destroying the turbo (you'll destroy your engine first )
