Hi there,
This is my first post, but I'd like to say that I have been circulating around here for a while and have enjoyed the great base of knowledge floating around this forum. Apologies for a long first post.
I'm having difficulty getting my 91 TD started. She has 504,000km but has been very solid until now. I've had her for 4+ years and she has a brand new 850CCA battery and the timing belt & tensioner were done by VW within the last 20,000km.
I figure that it is one of 2 things: fuel or timing. I would consider myself to be an 'intermediate' home mechanic. Fuel problems are within my realm...timing issues are new to me. So I am starting with a fuel system breakdown and am coming up short on answers, and your help would be greatly appreciated.
I have found a similar story here:
http://www.vwdiesel.net/forum/index.php?topic=17883.0But not all of my questions are answered. Here's the story:
Day 1: 15 degrees C and wet outside. Started no problems and drove for the afternoon doing errands.
Day 2: Almost exact weather conditions. Turned over but would not start. She would kick and "want" to start, but could not get it going.
Day 3: Figuring it was a fuel issue, I:
Checked voltage to Stop Solenoid ("click" on key)
Checked for any looseness or leaks around the IP
All clear lines to and from IP and filter pulled and checked.
Replaced fuel filter
Filter to water separator line pulled and checked. There was a blockage in that section, but I blew it clear.
Water separator to tank pulled and checked.
The temperature was warm enough that I did not spend my time on checking the glow plugs. I put it all back together, and eventually did get her to start, only to have her quickly die and not start again. I figured that I had put the lines back together leaving a fitting loose. So, I:
Pulled all lines again and blew them clear with a hand pump, including the water separator.
Replaced the tank to separator line.
Pulled and checked the fuel gauge sender and suction assembly.
With that done, I then confirmed that fuel was getting to each injector by cracking the connection to the top of each one individually and turning the car over.
Nothing. Same as before...she turns over and over and over. There are moments of slight "stumbles" but nothing more. There is fuel in the clear return line, I can see it moving as I turn the car over. There is plenty of exhaust as I turn it over, and it appears to be a normal colour.
From my research, my next actions will be to:
Double check the solenoid (as suggested in the above post)
Check the IP timing
Compression test (??)
Pull the injectors (would all 4 go at the same time??)
Thanks for any input!
Jason
