» TDI - VE Pump TDI Engines
View full version:
seeking expert on vp37 and Zexel Quantity Adjuster sensors
"Idle spring" on bosch VE pump.
Mk2 TDI swap obd and immo
Help identifying mount console for Injection Pump
AAZ pump question
MTDI pump
98 AHU 1.9TDI VE Injection Pump not delivering fuel
Mk1 ALH swap worthwhile?
1999.5 Golf ALH TDI - idles but that's it
VE TDI Injector Differences
AHU Optimum Cruise RPM
AHU P/S Delete Pulley Assy
Bought a done up ahu, what else should I upgrade??
hi to algl peoqle zdr
1Z constant white smoke
VNT Turbo Vane Position at Various Stages of Boost
Broke down at last. Vacuum pump oil leak.
Eating timing belts
Importance of the timing belt roller 028 109 244?
Weird coolant sender fault causing lowered mileage. ASV.
03 Golf-occasional white smoke
97 Passat TDI Runs Rough After warm up: No codes
TDI Didn't Benefit From Tune
1991 Golf AHU 1.9tdi
Oil Pressure Delay?
Need AFN Wiring diagram / pin out from BOSCH 028 906 021 ck (from VW Passat 96)
200/300tdi laro pumps different ore not?
Port Closure
Built a mech. VE-pump. Need help!
AHU with GT1749V
M-tdi alh
Asv timing failur
Tdim bad ring or Seal ??
ahu/1z 1.9L tdi vs aaz 1.9L idi with and without intercooler
Hello all
franken mTDI pump HELP!
Axial play on pump shaft?
What did I just buy?
Camshaft assembley error...
Compound turbos
Build idea spitballing
ASV bubbles
A Curious Thing......
2001 jettA IP SUCKING AIR
ALH TDI ticking noise
Valeo starter ?
AHU / Rover 300
Mk4 Jetta Master Window Switch Fix
Need some AHU education EGR delete?
