» mTDI Mechanical TDI Conversions
View full version:
4
Thoughts on mTDI AHU head porting
mTDI Passat b2 swap, your help is much appreciated
1.9 ALH Timing with pulse adapter and timing light help
Ordered an AAZ... Recieved a 1Z w/ mechanical pump... Will it work?
Setting static pump timing . 300tdi rover
LR Pump Innards into a MK4 Housing?
M-TDI ALH into a MK2 swap
MTDI dyno
1.6TD Pump on SDI Engine
mTDI Pump Tutorial on youtube!
AHU with AAZ pump problem
MTDI Mechanical VNT Control
Mtdi timing
Mtdi
12MM pump finally installed
1Z/AHU M-TDI build Toyota Pickup
mTDI Pump for Standard power AHU
LR 200 Pump help.
0460404065 pump question
mTDI / TDI-M Injection Pump FAQ
Realistic HP for mTDI
12mm pump runs
CJAA Conversion?
Land Rover pump timing question
Bad pump
New car- New Challange
Coming together nicely
Figured I'd introduce myself. Going to be putting an ALH into an 84 CJ7...
Vanagon Syncro AAZ to AHU mTDI Libby pump
Very little boost on my mTDI ALH Vanagon install
fuel injection pumps
AHU MTDI over rev issue
300 tdi landrover pump on an ALH TDI engine
1Z/AAZ mTDI Build
is there a Mechanical Pump for the 2.0 BHW?
Since we don't need the sensor on #3 is there better lines to use?
Witch Shaft you use for your 1.9 mTDI
VW 2.5 MTDI boat, fuel pump help
Engine RPM Sensor Connector
1.9TDI AGR (90hp) mTDI conversion.
Vanagon m-tdi idle timing
Vanbcguy's M-TDI Build
AHU vs. AFN
Urms mTDI build
ALH mTDI Rover 300TDI / GT2052 build - lack of power?
DI vs IDI dynamic timing
Ahu m- pump
79 rabbit MTDI river pump build!
What's this injection pump?
I got a M-tdi pump what's the plastic cover thing?
